While I was up at Grinspeed having my syncros fitted I also asked him to put a MFactory 5.46 Final Drive in there, same price labour so why not?
I had already used MFactory's gear calculator (
http://www.teammfactory.com/gear-calculator) and realised that I probably couldn't live with 4300rpm at 80mph in 6th so researched my options; found that an Accord 03-07 CL9 6th will fit and has a ratio of 0.659 which will return 6th to as near as dammed it oem levels. Bought the required parts from Lings but missed two small parts originally so it couldn't be fitted during my 1st visit to Grinspeed, gutted. It did mean I had to drive the 200 miles home with just the final drive installed; I was right, I couldn't live with it revving so high at motorway speeds, was great that I didn't have to change gear to hit vtec and power was instantly available, but after 3 hours it was doing my nut in!
I ordered the missing parts (collar and bearing needle costing £20!) and had them sent to Stevie, he was able to build up a gearbox and same final drive with the Accord 6th and confirmed it all worked now, great :WOOT
Accord 6th Main and Countershaft
MFactory 5.46 Final Drive (and syncros)
Crown Wheel
If anyone wants to do the same mod with their final drive then the info is below:-
Accord countershaft part number is same regardless of box syncro type, but for the mainshaft there are two part numbers being returned: 23590-RAS-010 & 23590-RAS-A00
Looking to google again regarding the differences I find this thread that refers to the difference between the two mainshafts:
http://forums.clubrsx.com/archive/index ... 361275.html
pre TSB
and post TSB
Speaking to Stevie he was able to confirm that Pre TSB = Double cone and Post TSB = single cone syncro type, my ep3 is an early 04 reg and it looks like TSB'd boxes are 05+ so that points to Pre-TSB (dual cone), but Stevie wasn't able to say for sure as mine was built in the transition period and they seemed to have just used what parts were available
If you're running dual cone syncros then you'll need to order pre-tsb mainshaft:-
23590-RAS-A00
but if you think your gearbox would be single cone syncro then the post tsb mainshaft is needed:-
23590-RAS-010
Parts Required
PFKL431117 (23491-RAS-000) GEAR,COUNTER 6TH 1
PFKL432653 (23590-RAS-A00) or
23590-RAS-010 if single cone syncro 05+ boxes GEAR COMP,MAIN 6T 1
PFKL1005139 BRG,NEEDLE 35X41X 1
PFKL434128 COLLAR,DISTANCE 2 1
