Down A Bit, Down A Bit, That's It...
#2701595
as i promised jerrick heres a pick of the car and how she sits on the meisterR coilovers
oh had the trackday at brands..... wow she was epic coilovers made a big difference. :bigthumb:
#2704349
Alight Everyone,
This Group buy as said is coming to an end shortly. :)
If you are interested in a set for your car, let me know and I'll sort something out for you.
Thank you everyone for the interests, and for the awesome pics of EP3 with the MeisterR coilovers for the gallery.
If anyone got any more pics, please feel free to send them to me. :)
#2755179
From what i've read on the rsx forum the dc5 chasis prefere a 50/50 spring rate where the front and rear require both 10kg for optimum performance.
The ep3 requires a harder rear spring, so minster have the coilover fitted with a 8Kg front and 10kg rear.
#2755723
Jay Type R wrote:With regards to the roll centre adjusters it states on your website that their for the DC5/EP3 and im sure I read up somewhere that these are different. Can you shed any light on this?
From what I understand, the EP3 Type-R and the DC5 Type-R use the same roll center adjuster.
But there are 2 more version for other variant of the chassis.
As this is a new product for me and the info is a bit incomplete because there can be a minor differences between UK, US, and JDM model.
But it is a case where either it will fit or it will not.
And if it doesn't fit I am 100% going to refund the full amount including postage, and find out what variant is needed for the UK EP3 model.
#2755727
gus-ep3 wrote:Regarding the spring rates, why are the DC5 rates heavier on the front than the EP3? :scratch:
I'm tempted to get a set of DC5 track rod ends so i can fit the heavier springs to my EP3, or can you order the 10kg springs in EP3 fitment?
Hawkins wrote:From what i've read on the rsx forum the dc5 chasis prefere a 50/50 spring rate where the front and rear require both 10kg for optimum performance.
Hawkins is correct that the EP3 prefer a heavier springs in the rear, where the DC5 prefer to have a more even balance springs rate.
That is due to the difference in the chassis, and also the standard suspension setup such as anti-roll bar, etc.
You can request to have the 10/10kg springs on a EP3 coilovers without any problem... but I would prefer to stick with the standard 8/10 setup as it is design with the EP3 chassis in mind. :)
#2755916
ive got a 10 10 set up works good i think :scratch:
#2756108
k20a@ep3spoon wrote: ive got a 10 10 set up works good i think :scratch:
Yep, the long as you like it, thats all it matters.
It is about personal preference, that is why the Zeta-R is adjustable as it mean there are a few ways for you to get the ride characteristic you want.
Also, other mods to the suspension system will change the personal preference or requirement to the springs rate also.
For example, you may want a 10/10 setup if you have a larger rear anti-roll bar, or you simply want less roll in the front and prefer the car to understeer a bit more on the limit so the car is more manageable.
But the standard 8/10 setup is design to be best compliant the standard setup of the EP3 suspension setup based on the standard suspension specification.
But no matter what the number says... if you are confident on how the car behave then there is no need to change anything.
As the old saying goes: "If it aren't broke, don't fix it!"
#2756250
gus-ep3 wrote:Hmmmm, more decisions for me now. :scratch:
Cheers for the replies lads. :thumbup:
go for it gus good bit of kit :thumbup:
Oh aye, there's no doubting that dude. :cool:
Its just i dont know if i want an 8kg or 10kg spring rate on the front now. :scratch:
