The usual rule of thumb is that you need 1 square inch of exhaust cross section per 60 flywheel bhp. FRom my calculations:
1. Greddy Evo - 246 bhp max@58mm internal diam. Rear muffler narrows to 30mm
2. Buddy Club - 283 bhp max@62mm internal diam. Silencer narrows to 25mm.
Note that this is related to the internal pipe diameter, outer diam is not so relevant, but a thick wall will help to keep exhaust velocity up, but weigh more. Restrictions/narrowing of the pipe will alter the otrque curve too. Silencer bungs and narrow mufflers will lose you power.
NO exhaust makes power, they merely release power that was being corked up. You should always match an exhaust to power output thus achieving torque curve you want:
Too big - loss of low-end torque. Good top end power.
Too small - good low end torque & loss of top end power.
Using the above equation you should achieve a good balance between low and top end power. THe buddy club on my car is slightly too big, and this pushes the torque curve to right slightly compared to TODAs car.
Ineed to go a couple of mm smaller.
