By NHB_EP3_Chris
#2507953
I'm loving the wide look of the Evo 8 wheels on the EP3's - enough so that I'm talking to a fella who has a set for sale at the minute.
Only issue is the tyres. My EP has stock suspension and the tyres on the Evo wheels are 235/45/17. I'm thinking from what you guys have said, these will rub like buggery unless I roll the arches and alter the camber? I have 215's on my OEM rims at the minute but am I right in thinking the enkies are a whole inch wider?
I'm starting to think that if I do need to, I may aswell lower it, roll the arches, fit camber bolts and get it setup all at once.
What do you guys think?
By raffopj
#2508234
NHB_EP3_Chris wrote:I'm loving the wide look of the Evo 8 wheels on the EP3's - enough so that I'm talking to a fella who has a set for sale at the minute.
I haven't fitted mine yet but i'm going run with 215's first then try 225's later on. Think the general rule is anything over 215 is going to rub when lowered... i don't know about standard suspension..... and I think that everyone thats fitted them so far has been lowered by 30mm or more
By bluntcap
#2508244
You still not fitted them mate? Still keeping them white?
By raffopj
#2508351
Not yet mate.... have 2 sitting in my torpedo boot with the 888's on... need to sort out 2 more tires.... thinking 225/45's for the front lol maybe Kumoh Escta V70A's :oops: as the toyo's are crazy monies
and yeah still sticking with white.... for the minute
By NHB_EP3_Chris
#2508574
Thanks raffopj, I'll bear that in mind. :thumbup:
Does it make a big difference in ride quality when lowered 30mm?
The missus and I are expecting a newborn in the next few days and I'm going to be using the EP3 to ferry them about to she shops etc. Just don't want to wake the little terror when she finally falls to sleep (the baby I mean, not the missus!).
By kezzad999
#2509184
alright fellas,
just wondering if the 205 oem tyres would fit on these
some places ive seen says you can some says you cant?
prob a silly question due to a lot being 235
just bought 4 brand spankers for the beast
and have found some rim only for a reasonable price?
any help much appreciated
many thanks
By NHB_EP3_Chris
#2509947
kezza - there is a car on the 1st page with 205/40 tyres fitted to these rims, so I'd hazard a guess and say yes it can be done - 40's will have a stiffer sidewall compared to 45's.
By kezzad999
#2510001
ahhh ye! missed that was looking below the ss ctr! cheers for that mate! think ill try them with the 205s wear them out then go on to 235s
thanks again mate
By NHB_EP3_Chris
#2510006
No worries mate.
I actually prefer the stretched look. I'd probably go for 215s for a good compromise between having the stretched look and a good contact area
By kezzad999
#2510016
i really like the look of that ss ctr on page 1. but cant imagine it would look that different!! 215s it is ha!
cheers pal
By NHB_EP3_Chris
#2510037
I know what you mean it does looks really smart. I think it's also the low tyre profile which gives them that rubber-band look.
I've got 205/40s on my OEM wheels on the back of my car at the minute but I wouldn't recommend it unless you don't mind a harser ride. When I go over speed bumps the back-end always makes a massive thud. I've got 215/45s on the front and they are much more forgiving and don't alter your speedo (which is why the others are on the back).
By kezzad999
#2510053
thinking itll be 205s all over then 215s on the back while i use the 205s then 215s all over then :) ! am i daft for assuming 235s would rub more??
By NHB_EP3_Chris
#2510057
well I can't say for certain as I also was wondering if 235s would rub when running std suspension, but you would definately be risking it I think. I'd say the smaller the tyre the less likely they are to rub.
The Enkei wheels I was looking at had got 235s on all four but still had plenty of tread left. Would seem a shame to just take them off and get no use out of them at all. I'm now looking at a set of Inovit wheels as another option (see my other thread). They are copies of the rota torques but are only £344 for a set!
By kezzad999
#2510066
they look cool!! and cheap! beauty of the enkeis as well!! sure you could just use the 235s until they're done with? wanting a gruppe m soon as possible as well so going to have to recycle my tyres ha!!
By NHB_EP3_Chris
#2511217
I've just had a reply from another guy with a set of these Enkeis for sale. They have done 3k miles with good potenza tyres (235/45) and he wants in the region of £200. I'm a bit unsure whether to take the plunge to be honest. What do you guys think?
By jonkun
#2524410
would enkei's shod in 235/45 rubber fit under the arches of a standard civic? or would modifications need to be made?
By raffopj
#2553043
ab20000 wrote:Anybody know the weight on these? Not just a guess but an exact weight. :thumbup:
i measured one and it came up at 8.9kg. Scales are pretty accurate i think. :thumbup:
  • 32
