andazw wrote:The slot next to the handbrake on my Ep3 is the ideal length for holding a twix xl
Audi A3 Black Edition - Sold
FN2 CTR - Sold
EP3 Satin CTR - Sold
Barney wrote:Stevo M81 wrote:Not a tolborone?andazw wrote:The slot next to the handbrake on my Ep3 is the ideal length for holding a twix xl
vtrsp1rob wrote:owned my civic 6 years and only just realised today the rear window squirter works if you turn the switch either clockwise or anticlockwise!slow clap lol
t100ypr wrote:Ha! was a 5.30 am while I was half asleep when I spotted it too!vtrsp1rob wrote:owned my civic 6 years and only just realised today the rear window squirter works if you turn the switch either clockwise or anticlockwise!slow clap lol
vtrsp1rob wrote:owned my civic 6 years and only just realised today the rear window squirter works if you turn the switch either clockwise or anticlockwise!There's a squirter on the back windows.?! Mine must be broken
jock_lock wrote:Thats just the garage being lazy because its a pain in the arse to clean it out after that stuff in the tyre. If clean it out properly so its able to take the glue its fine.l30bar wrote:yes it is true ....the spare doesn't fit the fronts....so honda have made it nice and hard for you, By making you take of the back wheel aswell, so you can fit that to the front and put the spare on the back!....but if you think ahead....Go buy your self a tyre Gas canister that inflate's the tyre then you can drive to the kwick fit men to repair it!Er, if you use the gas canister stuff, you can't get the tyre repaired afterwards. That can make it an expensive puncture.
TrottaEP3 wrote:If you put something in the front passenger footwell and then go to retrieve item, the gear knob is perfectly placed to give you a black eye......!!!So true - found that out a couple of times recently.
RoBMX wrote:FN2, Windows down so you can see the wing mirrors first thing, reverse, stop quickly due to cat, entire contents of roof - be that rain, snow or both - falls into the drivers side open window and into your lapWhat are you talking about Robthis is after all the water running off the boot when you open it going straight down the back of your neck of course.
Stevo M81 wrote:RoBMX wrote:FN2, Windows down so you can see the wing mirrors first thing, reverse, stop quickly due to cat, entire contents of roof - be that rain, snow or both - falls into the drivers side open window and into your lapWhat are you talking about Robthis is after all the water running off the boot when you open it going straight down the back of your neck of course.
