Post your power charts here.
By L_S_i
#3595545
Well now im in UK and just started working slowly, here´s the result from a friends car in a dyno dynamics.
Specs:
Darton sleeved 2300 cm3 stroked k20
Brian crower stg3 camshafts & valvetrain
toda header
2,75 " catback
stock rbc and gruppeM
70 mm tb
rc 750
kpro
There´s still some things to improve regarding intake, exhaust and fueling, also its a conservative tune since well be back in the dyno with some new mods and bolt ons.
Uploaded with ImageShack.us
By jreedy
#3595635
OZ 82 wrote:That torque is SC level!
My charged civic was 182 ftlb's
My turbo'd one was 206 ftlb's
What other bits you adding before the final tune? Also what power are you hoping for on the final tune?
Nice build :-)
By motty
#3595704
L_S_i wrote:builted block , 88 mm cp 12.5 cr, darton sleeved, 92mm crank Brian crower stroker and stg 3 camshafts.
The new adds will be costum 3" ehxaust, costum header, ID injectors, fuel pump, new intake manifold ( dont know yet what will be) and 3,5" intake CAI
could you not run some ITB's like toda etc on a setup like this?
By mezmo
#3595710
Nice build :-)
Your charged civic was only 182 ft lb? Was that at 8/9 psi?
That seems quite low mate, most jrsc torque figures that I've seen are circa 190-200 lb ft.
This sounds impressive matey, any pics also you should start a build thread [smilie=karls_thumb.gif]
By jreedy
#3595762
mezmo wrote:
CTRSam wrote:The turbo torque seems very low
My Rotrex is 227lbft
I did think it was a bit low too, unless the psi is set lower.
My charged civic was running 295 and I'm sure it was 182 ftlb's @ 8psi...... Could be wrong though
My turbo'd type r was 321 and not much more than 200 ftlb's at 7 psi with a cpl re hard kit
Both were very quick though :-)
Edit- my turbo'd ep3 had 225 ftlb's of torque and 321 Bhp with just 7 psi
#3607374
Ive heared about this from a local friend, who knows the owner or friends who were here at birmingham A38 3-4 nights ago.
quite impressive this.
New car incoming
