Malfunction
DTC Scan tool - P0011 - 56-2 (56) - VTC System Malfunction
DTC Scan tool - P0107 - 3-1 (3) - Manifold Absolute Pressure (MAP) Sensor
Circuit Low Voltage
DTC Scan tool - P0108 - 3-2 (3) - Manifold Absolute Pressure (MAP) Sensor
Circuit High Voltage
DTC Scan tool - P0112 - 10-1 (10) - Intake Air Temperature (IAT) Sensor Circuit
Low Voltage
DTC Scan tool - P0113 - 10-2 (10) - Intake Air Temperature (IAT) Sensor Circuit
High Voltage
DTC Scan tool - P0117 - 6-1 (6) - Engine Coolant Temperature (ECT) Sensor
Circuit Low Voltage
DTC Scan tool - P0118 - 6-2 (6) - Engine Coolant Temperature (ECT) Sensor
DTC Scan tool - P0122 - 7-1 (7) - Throttle Position (TP) Sensor Circuit Low
Voltage
DTC Scan tool - P0123 - 7-2 (7) - Throttle Position (TP) Sensor Circuit High
Voltage
DTC Scan tool - P0131 - 1-1 (1) - Primary Heated Oxygen Sensor (Primary
HO2S) (Sensor 1) Circuit Low Voltage
DTC Scan tool - P0132 - 1-2 (1) - Primary Heated Oxygen Sensor (Primary
HO2S) (Sensor 1) Circuit High Voltage
DTC Scan tool - P0133 61-1 (61) T61-1 Primary Heated Oxygen Sensor (Primary
HO2S) (Sensor 1) Slow Response
DTC Scan tool - P0135 - 41-2 (41) - Primary Heated Oxygen Sensor (Primary
HO2S) (Sensor 1) Heater Circuit
Malfunction
DTC Scan tool - P0137 63-1 (63) T63-1 Secondary Heated Oxygen Sensor
(Secondary HO2S) (Sensor 2) Circuit Low
Voltage
DTC Scan tool - P0138 63-2 (63) T63-2 Secondary Heated Oxygen Sensor
(Secondary HO2S) (Sensor 2) Circuit High
Voltage
DTC Scan tool - P0139 63-3 (63) T63-3 Secondary Heated Oxygen Sensor
(Secondary HO2S) (Sensor 2) Slow
Response
DTC Scan tool - P0141 - 65-2 (65) - Secondary Heated Oxygen Sensor
(Secondary HO2S) (Sensor 2) Heater
Circuit Malfunction
DTC Scan tool - P0171 45-2 (45) T45-2 Fuel system Too Lean
DTC Scan tool - P0172 45-1 (45) T45-1 Fuel system Too Rich
DTC Scan tool -P0300 and some of P0301 / P0302 / P0303 / P0304
- 71-1 (71)
72-1 (72)
73-1 (73)
74-1 (74)
- Random Misfire
DTC Scan tool - P0301 71-1(71) T71-1 No. 1 Cylinder Misfire Refer to the 2001
DTC Scan tool - P0302 72-1(72) T72-1 No. 2 Cylinder Misfire Refer to the 2001
DTC Scan tool - P0303 73-1(73) T73-1 No. 3 Cylinder Misfire Refer to the 2001
DTC Scan tool - P0304 74-1(74) T74-1 No. 4 Cylinder Misfire
DTC Scan tool - P0325 - 23-1 (23) - Knock Sensor Circuit Malfunction
DTC Scan tool - P0335 - 4-1 (4) - Crankshaft Position (CKP) Sensor No
DTC Scan tool - P0336 - 4-2 (4) - Crankshaft Position (CKP) Sensor
Intermittent Interruption
DTC Scan tool - P0340 - 57-1 (57) - Camshaft Position (CMP) Sensor No
Signal
DTC Scan tool - P0344 - 57-2 (57) - Camshaft Position (CMP) Sensor
DTC Scan tool - P0341 - 57-3 (57) - VTC Phase Gap
DTC Scan tool - P0420 67-1 (67) T67-1 Catalyst System Efficiency Below
Threshold
DTC Scan tool - P0443 - 92-4 (92) - Evaporative Emission (EVAP) Canister
Purge Valve Circuit Malfunction
DTC Scan tool - P0500*1 - 17-1 (17) - Vehicle Speed Sensor (VSS) Circuit
Malfunction
DTC Scan tool - P0563 - 34-2 (34) - Engine Control Module (ECM)/Powertrain
Control Module (PCM) Power Source
Circuit Unexpected Voltage
DTC Scan tool - P0600 - 39-1 (39) - Serial Communication Link Malfunction Refer to the Multiplex
Control System
DTC Scan tool - P1107 - 13-1 (13) - Barometric Pressure (BARO) Sensor
Circuit Low Voltage
DTC Scan tool - P1108 - 13-2 (13) - Barometric Pressure (BARO) Sensor
DTC Scan tool -P1259 - 22-4 (22) - VTEC System Malfunction
DTC Scan tool -P1297 - 20-1 (20) - Electrical Load Detector (ELD) Circuit Low
Voltage
DTC Scan tool -P1298 - 20-2 (20) - Electrical Load Detector (ELD) Circuit High
Voltage
DTC Scan tool -P1361 - 8-2 (8) - Top Dead Centre (TDC) Sensor
DTC Scan tool -P1362 - 8-1 (8) - Top Dead Centre (TDC) Sensor No Signal
DTC Scan tool -P1519 - 14-3 (14) - Idle Air Control (IAC) Valve Circuit
Malfunction
DTC Scan tool - P1607 - 0-2 - Engine Control Module (ECM)/Powertrain
Control Module (PCM) Internal Circuit
Malfunction
