Page 1 of 2
Back in an ep3
Posted: Sun Feb 14, 2016 8:44 am
by jonnyb86
So yesterday I picked up a satin silver ep3 after regretting selling my cosmic grey premier years ago when my username in here was Jonnybep3
So a little about the new car its a 2005 premier with a few mods some I like some I will be changing
Lowered on ABP eiback springs
Front camber bolts
Rear buddy club camber arms
Tegiwa M
Tegiwa M intake hose
E-tech front strut brace
Spoon N1
Android head unit
Skunk 2 weighted gearknob
Tegiwa short shifter
Preface rear lights
Plans are to remove the rear lights and fit facelift ones, remove the N1 and fit a standard backbox as its too loud for me and possibly change the springs for the pro kit but as of now I'm absolutely loving it
Cheeky pic of my old cosmic
Re: Back in an ep3
Posted: Wed Feb 17, 2016 6:44 pm
by 160mph_boy
You chose the fastest colour..
Re: Back in an ep3
Posted: Wed Feb 17, 2016 6:55 pm
by matthewson
Looks good mate! I might be interested in the lights when you swap!
Re: Back in an ep3
Posted: Sun Feb 21, 2016 6:30 pm
by jonnyb86
Thanks guys the rear lights will be up for sale as soon as I get a set of facelifts so I will pm you as soon as I get them off
Re: Back in an ep3
Posted: Sun Feb 21, 2016 8:29 pm
by wHAmEz
What wheels are those? They look awesome [THUMBS UP SIGN]
Re: Back in an ep3
Posted: Sun Feb 21, 2016 10:53 pm
by w6ady
Look like rota blitz mate
Re: Back in an ep3
Posted: Sun Feb 21, 2016 11:49 pm
by jonnyb86
Yeah they were rota blitz
Re: Back in an ep3
Posted: Mon Feb 22, 2016 9:55 am
by Rigsby01
Im doing exactly the same mate, picking my second ep3 up on saturday.
You got a good one there mate, i saw it for sale as well but was too far for me to travel
Re: Back in an ep3
Posted: Mon Feb 22, 2016 11:59 am
by jonnyb86
Cheers mate this is my 3rd ep3 and I'm absolutely loving it again.
Re: Back in an ep3
Posted: Mon Feb 22, 2016 8:15 pm
by jonnyb86
this morning on the way to work under partial throttle I felt a slight misfire so after work I pulled the car into the workshop connected it to the HDS and scanned for code but not DTC's found but noticed in the data list the misfire count was high and showing a problem with number 2 cylinder I removed all 4 coil packs and found number 2 to be damp and managed to trace the culprit to a slight pin hole in my washer tube and when I was spraying the washers a tiny amount was spraying out the pin hole and making its way past the coil and wetting the spark plug so out with the old plugs and new plugs fitted and washer hose repaired problem solved
Hopefully this weekend I will tackle the engine bay and give it a good cleaned you can see it needs it
Re: Back in an ep3
Posted: Mon Feb 22, 2016 8:38 pm
Double check them new spark plugs are correct. I'm pretty sure you're suppose to use iridium tipped spark plugs.
Re: Back in an ep3
Posted: Mon Feb 22, 2016 8:56 pm
by jonnyb86
Your 100% right mate but as it was after half 5 and the parts department had closed I only had these in my toolbox correct fitment, length and heat range so done the job to get me up the road but will definitely be getting changed out tomorrow when I can get my hands in iridiums
Re: Back in an ep3
Posted: Sat Feb 27, 2016 1:23 pm
by jonnyb86
Re: Back in an ep3
Posted: Mon Mar 07, 2016 8:54 pm
by jonnyb86
After work tonight I removed the n1 and fitted the standard backbox sounds alot better now but forgot to get a pic. Debating with myself whether to refurb the oem wheels or fit the Rota torques that came with the car
Re: Back in an ep3
Posted: Tue Mar 08, 2016 6:11 pm
by matt ep
LOVED your old cosmic! Inspired me somewhat with my car. You were part of MonsterUnit right? The Rota Blitz' have always tempted me but only on your car have they ever looked right IMO. The Stance on the above pic is perfect.
Nice new toy also! Will definitely keep an eye on this
Re: Back in an ep3
Posted: Tue Mar 08, 2016 11:07 pm
by jonnyb86
Cheers mate I appreciate it
Re: Back in an ep3
Posted: Wed Mar 16, 2016 8:09 pm
by jonnyb86
Anyone interested in a swapping rear lights as I'm really not liking the preface lift rears
Re: Back in an ep3
Posted: Wed Mar 23, 2016 11:14 am
by jonnyb86
Fitted the rota's last night
Re: Back in an ep3
Posted: Wed Mar 23, 2016 9:23 pm
by Rigsby01
Looking good
Re: Back in an ep3
Posted: Mon Jun 06, 2016 5:02 pm
by jonnyb86
Starting to get the urge to put this up for sale but struggling to make my mind up on what I would change it for anyone got any ideas?
