Page 1 of 2
Exhaust diameter & power potential
Posted: Tue Dec 23, 2003 7:35 pm
by stanwan
I've been doing a few calculations on aftermarket exhausts for the CTR and their power potential.
The usual rule of thumb is that you need 1 square inch of exhaust cross section per 60 flywheel bhp. FRom my calculations:
1. Greddy Evo - 246 bhp max@58mm internal diam. Rear muffler narrows to 30mm
2. Buddy Club - 283 bhp max@62mm internal diam. Silencer narrows to 25mm.
Note that this is related to the internal pipe diameter, outer diam is not so relevant, but a thick wall will help to keep exhaust velocity up, but weigh more. Restrictions/narrowing of the pipe will alter the otrque curve too. Silencer bungs and narrow mufflers will lose you power.
NO exhaust makes power, they merely release power that was being corked up. You should always match an exhaust to power output thus achieving torque curve you want:
Too big - loss of low-end torque. Good top end power.
Too small - good low end torque & loss of top end power.
Using the above equation you should achieve a good balance between low and top end power. THe buddy club on my car is slightly too big, and this pushes the torque curve to right slightly compared to TODAs car.
Ineed to go a couple of mm smaller.
Posted: Tue Dec 23, 2003 7:46 pm
by smudger1980
So what effect do u think my top gear exhaust will have had Stanwan if any based on ure above post?
Its 57mm bore with 4.5inch tailpipe.
My ctr is standard except for a K&N replacement filter.
Smudger 8)
Posted: Tue Dec 23, 2003 7:47 pm
by GP Shop
Hi dude,
I've emailed Mugen, and waiting their response in regards to your pipe diameter question for the twin loop :)
Michael
Posted: Tue Dec 23, 2003 8:04 pm
by Trung
I have the Mugen Sports exhaust specs now.
E-mail from King M.S.:
'Thank you for your email. The Mugen JDM EP3 exhaust uses 54mm tubing to the center resonator and 60.5mm tubing from the resonator back. The reason Mugen steps the exhaust is to increase the mid-range. The total weight for the Mugen exhaust system is 29lbs.
We have this part in stock and ready to ship.
Please let us know if you need further assistance.'
Posted: Tue Dec 23, 2003 10:17 pm
by alanb
i hate compromises!
loss of low end means around town ur a bit slower?
but its rpm isnt it? so if ur hoking it most of the time bigger is better?
yes it will take longer around tesco carpark(who cares?) but on dual carriage ways etc provided ur keeping the revs up u'll extract the max?
Posted: Tue Dec 23, 2003 10:23 pm
by type-r 69
what about fujitsubo rmo1a does anyone no what diameter that is its a good quailty exhaust
Posted: Tue Dec 23, 2003 11:36 pm
by stanwan
Aha Mugen is no good for tuned cars then! The narrower centre section will give good torque, but will limit top end.
Posted: Tue Dec 23, 2003 11:37 pm
by stanwan
smudger1980 wrote:So what effect do u think my top gear exhaust will have had Stanwan if any based on ure above post?
Smudger 8)
57 bore will be fine for a mildly modded car. it doesn't narrow at the rear silencer does it?
Posted: Tue Dec 23, 2003 11:47 pm
by smudger1980
think it does Stanwan at the rear as it shows in the pic there but im not sure to what size cause I aint measured it. Will this make a difference then?
Smudger
Posted: Tue Dec 23, 2003 11:48 pm
by alanb
and the logic of all this is to have 2 exhausts just like the cams
one for low rpm and one for high rpm
what a unique idea!
not beyond engineering capability!
u split into the two at end of manifold and a switch actuated on revs!
eureka!
Posted: Wed Dec 24, 2003 9:08 am
by johnny74
so is the spoon ideal for our car then
Posted: Wed Dec 24, 2003 9:10 am
by type r daddy
johnny74 wrote:so is the spoon ideal for our car then
Too late for me if it is mate!! i took your advice!!
Posted: Wed Dec 24, 2003 10:17 am
by johnny74
i'm sure it is m8ty because I like to lick cows udders and its the only one i'm getting
Posted: Wed Dec 24, 2003 4:01 pm
by RussellT
Anyone know the i/d of the hayabusa? I thought that was 60mm, this would be ideal for 'toda' spec cars if it didn't narrow at the silencer, would it not. Thought the mugen twin loop would have been bigger than that, sure toda have used one on their RSX demo in the states (will find out, not 100% at the mo).
Russ.
Posted: Wed Dec 24, 2003 4:46 pm
by alanb
yeh i emailed todaracing in us but they wouldnt tell me which mugen!:
'You are receiving this message because you:
-Have requested product support from TODA Racing USA but you are not located
in North America.
-Have purchased TODA products outside of North America and are contacting
TODA Racing USA for product support.
-Are located in North America, but did not purchase your TODA products from
us or one of our authorized dealers. (you purchased from greymarketers)
For the above mentioned reason(s), we will not provide any tech support.
Tech support is ONLY provided to customers within North America who have
purchased products from TODA Racing USA or one of our authorized dealers.
Best Regards,
AKH Trading/TODA Racing USA
Tel 714-327-0181
Fax 714-327-0184
http://www.todaracing.com
-----Original Message-----
From: ABooth2000@aol.com [mailto:ABooth2000@aol.com]
Sent: Tuesday, December 23, 2003 2:28 PM
To: toda@todaracing.com
Subject: Re: Toda Program
Dear Sirs
Which Mugen Exhaust system did you use in this test
Alan Booth
Posted: Thu Dec 25, 2003 2:10 am
by Gokou
alanb wrote:and the logic of all this is to have 2 exhausts just like the cams
what a unique idea!
eureka!
I've seen mufflers with motor controlled valve to vary back pressure on this website, http://www.car-accessory.com.tw/cgi-bin ... rodID=1627
Posted: Thu Dec 25, 2003 8:51 am
by UCB
Isn't this what Ferrari do to get past euro noise regs?
Posted: Thu Dec 25, 2003 7:42 pm
by andyd
what about the Skunk or is that no good???
Andy
Posted: Tue Dec 30, 2003 8:53 pm
by stanwan
Back pressure isn't the issue. Certain pipe diameters will accellearate exhaust gas better at a defined rpm range. Matching this load to the exhaust can improve breathing. Smaller diams accellerate gas better at low rpm and larger diams the opposite. The trick is getting the pipe size right for the perofrmance you want.
Too big -l ose low end torque, too small and you limit top end power. THe TODA collector i believe is 55mm! So stepping up from that should suffice...
Posted: Tue Dec 30, 2003 9:10 pm
by Trung
stanwan wrote:THe TODA collector i believe is 55mm! So stepping up from that should suffice...
60mm I believe. :!:
The Toda B16/B18 has 60mm collector so I'll be suprise if K20A uses smaller diameter.
