By Type R-Matic
#3793510
Hoping for some help on sizing.
Was looking at
PCD-5x114.3
Offset-et45
Would that work on ep3?
Not sure what width is best for ep3 though.
Whats best for a straight fit? And would my tyres from standard wheels fit?
Thanks for any help guys
By shaRRpy
#3793512
Yes they would fit fine,as for width if you just want a straight forward fit then 7.5 would be good or if you want to roll your arches then you could go 8j or even 8.5 with some camber.as for tyres I'm assuming you're running 205 and they would be fine on 7.5 and a little stretch on 8j but would be ok and then when you need new tyres upgrade to 215 or 225.hope that helps.
By Type R-Matic
#3793533
shaRRpy wrote:Yes they would fit fine,as for width if you just want a straight forward fit then 7.5 would be good or if you want to roll your arches then you could go 8j or even 8.5 with some camber.as for tyres I'm assuming you're running 205 and they would be fine on 7.5 and a little stretch on 8j but would be ok and then when you need new tyres upgrade to 215 or 225.hope that helps.
Thats perfect thanks dude, massive help :salut:
