By t2pkm
#2668624
When you fit these wheels do it with the centre cap not fitted and you will see the spigot ring just spin freely on the hub thay don't do anything ??? I got the size everybody said to use ? Have driven car without the spigot rings and I don't get any wheel wobble. Has anybody else found this just a bit curious :scratch:
By gavst205
#2669406
You cant move mine at all when fitted.
Spigot rings are not only to ensure the wheel is central on the hub, preventing wobble.
Its main job is to fill the gap between hub and wheel centre so its the actual hub supporting the weight of the car. If there is a gap, the weight of the car is support by the studs themselves which they are not designed to do and can break.
I've seen it happpen, not pretty :roll:
Just found this.
http://www.nice-wheels.co.uk/pcdandoffset.html
By t2pkm
#2669833
So how do I sort this problem ? The the spigot ring you all say to use and the right wheel nut I have fitted :scratch:
By t2pkm
#2669862
cheers gavst205 will try and fit spigot rings tommrow and have a look. the guy at the wheel refurb place fitted mine and thats what he told me,he said the ring wasnt doing anything so he didnt fit them, you have worried me a bit cheers for the help my spigot ring size is 64.1-67.1 is this the correct size and do you fit them inside the wheel or direct on hub ? :bigthumb:
By gavst205
#2669942
Thats the same size i've got where did you get them from ? Maybe measure it to make sure it is what its supposed to be. Is it loose on the hub or in the wheel ? Mine are a tight fit on both.
Its easier to fit them in the wheels rather than fit them on hub and try to put wheel over top. But strictly speaking it doesn't matter which wasy you do it.
By t2pkm
#2670683
just had a look and i have been sent wrong rings have orderd correct ones of ebay cheers for the help gavst205 car should be sorted next week will not be driving it till correct rings fitted :thumbup:
By btf
#2678302
i got a set of evo 9 wheels, i think they are 38mm offset, will they fit with 235/45/17 tires? how differently will they perform? you think i can get away with it by just rolling the fenders or maybe no modifications? stock suspension here. thanks
By gavst205
#2678395
You'll definately have to roll arches on the back if trying to run 235's you might get away with the 45's as you've running @ stock height but it'll be close.
Another thing to remember is that with stock suspension you'll probably get a bit more movement than with uprated suspension with it being softer.
By alexrctr
#2679282
Looking for a set of these alloys, preferably standard silver. Drop me a pm if anyones thinking about selling theirs :thumbup:
By gavst205
#2680640
Were your arches standard though?
Would they have been okay if you rolled arches ?
By supercharged ctr
#2724344
hi all, had a look at this thread the other day and love the evo wheels on a civic, so much so that i bought a set. pick them up on sunday. :-D cant wait to fit them. think im going go for 205/40/17.
By supercharged ctr
#2726984
picked up the wheels today, in better condition than i thought, still going refurb them though. going get started on them tomorra morning at work. :-D hope to get them on soon. but first need to get some spigots ring, wheel nuts and new enkei stickers.
wot size spigot rings do i need to get?
thanks steve
By t2pkm
#2731986
Has anybody got these wheels with abp springs with the standard type r tyres fitted to them and do you have any problems ? :vconf:
  • 32
