It's not even 4 tanks of fuel difference in tax, more like 1.5, think I could manage that.
Anyone know how the old one compares to the new? I'm under the impression so far as it's the same as ep3 vs fn2.
Mugen Cosmic R
PSN: Tenzo-uk
Tenzo-R wrote:Yea the first year is dearer on new cars because of global warming/the boogey man/eskimo's and other made up stuff.
Ross_B wrote:they are very under-tuned as standard, so see huge gains from relatively simple mods. Akin to an EP3 in that way i guess.yeah, sounds exactly like the EP3, it is cheap as chips to get massive gains from
Abraham Lincoln wrote:don't believe everything you read on the internet
Tenzo-R wrote: Anyone know how the old one compares to the new? I'm under the impression so far as it's the same as ep3 vs fn2.Mk2 has all the main complaints from the Mk1 sorted, so the steering is a bit better (still not brilliant) the aero kit is standard, stiffness has increased by 41% and the suspension has been sorted. The torque steer has been better kept under control and unless on wet B roads you don't notice it at all, the Mk2 benefits hugely from it's chassis developed for the Focus RS so it can put the power down a touch easier.
kingofdbrits wrote:I've found the Mk2 quite restrictive in 1st & 2nd but you can press the DSC OFF button which gives you full power & torque should you want it, it may just be me but the throttle also feels more responsive with the dsc off. It has to be dry and a good road though as it's not difficult to light up the fronts on a damp road.
They've not made a engineering breakthrough to control the power at low speeds, just an electronic brain holding more back until you get into third gear.
It does give an interesting sensation of just getting faster and faster as you climb through the gears.
With the DSC on, i wouldn't be surprised if the Mk1 was a bit quicker to 60 and as the Mk2 is a bit lighter and has more torque and power lower in the rev range the Mk2 could well be a bit quicker over 1/4 mile. Then there'll be so little between them the driver will make a much bigger difference and who ever puts their foot down first.
Tenzo-R wrote:Is there a common fault with the dsc/abs?
danneth wrote:where you going for the remap mate, ive just ordered the hypertech for nowThinking about Litchfield Imports as they are the closest to me, they will do the ecutek for £450 which should see 290-300bhp plus they have good experience working with turbos.
danneth wrote:p.s inside vids neededWill do tomorrow as i'll most likely get up for an early morning drive.
Newannaive wrote:Litchfield Tewkesbury..?It is the one in Tewkesbury. There are good mazda tuners in Newcastle, Bradford and in Kent so the only one in the midlands is Mr Litchfield.
Does that filter thingy have a scoop thingy underneath it..?
