By RevHard
#789230
Since CTR does not have LSD (edm) I would like to discuss what LSD have u put in ur tranny, what were the problems if any and how does it feel
I mean that LSD is urgent in a car like CTR....
By Awesam
#789235
Go for the Quaife LSD, Its Maintenance free and good for about 300-400bhp
While u are getting the LSD fitted i recommend changing your flywheel and clutch.
By moNoKnoT
#789242
Awesam wrote:Go for the Quaife LSD, Its Maintenance free and good for about 300-400bhp
I agree, gets very expensive doing this but worth the extra just to save labour costs.
- Kevin.
By Tarticus
#789275
Best mod I had fitted by far also had clutch changed and Flywheel changed for an Exedy Lighter item :P
By RevHard
#789339
What about extra rings, bearings that need to be fitted with the LSD?
Does the quaife sit in the tranny with no problems?
By Tarticus
#789356
Aint sure what your on about here, the quaife item is a sealed unit, and as far as I know there aint no bearings / rings to be fitted, it just sits in the tranny with no problems like you say.
Had mine fitted by CPL Racing and its superb
By hyro
#789380
i have tested quaife lsd and cusco RS in my ctr. cusco is a lot better than
quaife, there is a huge difference between them, but cusco has manteinance and quafe doesn't.
i am very happy with my cusco RS
By Awesam
#789446
RevHard wrote:What about extra rings, bearings that need to be fitted with the LSD?
Quaife sits with no porbs, the bearing are replaced when its fitted! Not sure about the extra rings.
By Awesam
#789462
Just discovered that Mugen do an LSD!!
The price is about £670 plus postage from Takhaira
By andyd
#790303
Awesam wrote:Just discovered that Mugen do an LSD!!
your a bit slow :lol: :lol:
i have one as std on mine 8)
Andy
By Awesam
#790466
Andy
lol
do u blame me!! it took them ages to bring out a mani!
By slep
#790753
I have spoon LSD, I'm very happy with it.
The torsen type LSD isn't comparable in performance than the clutch 1.5 way LSD type (Cusco, Spoon ...).
By HASNIC
#790779
slep wrote:I have spoon LSD, I'm very happy with it.
But then having the rebuild cost for me outweighs any performance increase.
By Liability
#791339
Just fitted a quaife. Love it. Also fitted an exedy clutch but didn't see much point in doing the flywheel. Gains for £s didn't seem worth it to me as a replacement for an 04 flywheel.
By HASNIC
#791342
Liability wrote:Just fitted a quaife. Love it. Also fitted an exedy clutch but didn't see much point in doing the flywheel. Gains for £s didn't seem worth it to me as a replacement for an 04 flywheel.
Good man :D :D
By mr_typeR
#838843
whats the cost of the lsd and clutch supplied and fitted?
Andy
By si
#838852
think its roughly £1000 mate
By mr_typeR
#838854
sorted :D thinking about going for a JRSC would it be ok with 5psi without the lsd and clutch? just until i can afford the extra expense??
By si
#838857
mr_typeR wrote:sorted :D thinking about going for a JRSC would it be ok with 5psi without the lsd and clutch? just until i can afford the extra expense??
you can but dont expect the clutch to last that long. Its all down to how much mechanical sympathy you have to be honest. If you start doing 1/4 miles and track days etc then the clutch will not last long at all.
drive it like its a 1.0 micra (launch slowly and dont thrash it) and it should last a while, until you can afford to replace them anyway.
Its pretty risky and id make sure you have the emergency cash there waiting "just in case" if you were going to risk it. Someone on here had done 1k miles on the standard clutch before it died when they were down the pod.
http://civictype-r.co.uk/forum/viewtopic.php?t=68779
By Tarticus
#839703
sorted thinking about going for a JRSC would it be ok with 5psi without the lsd and clutch? just until i can afford the extra expense??
All ill say is save a bit more cash or get the LSD first, its down to peoples choice really and really what they do and how they drive there cars.
Daily driving, ok the standard set up and cutch will be ok, but giving it some hammer (and we didnt buy Type Rs to drive round like miss daisy) then I would deffinately at least get the LSD.
The question is when fitting the LSD or a Clutch you may as well do it all together doing Clutch LSD Flywheel all at the same time to save on labour costs.
If your tracking the car, or especialy drag racing then an uprated clutch and LSD is a must.
And geta QUIFE ATB Diff its by far the best on the market :P (I know I got one)
