By redchris
#1871544
Is it generally agreed that the problem with CTR's pulling to the right (or left) is down to a duff steering rack? I'm seriously considering buying one but reading that thread frightens me! I don't want to spend all my time wrestling with the car!!
By Newannaive
#1871549
redchris wrote:Is it generally agreed that the problem with CTR's pulling to the right (or left) is down to a duff steering rack? I'm seriously considering buying one but reading that thread frightens me! I don't want to spend all my time wrestling with the car!!
no it's not....could just as easily be tracking or duff tyres....a faulty steering rack is usually paired with a loud creaking noise.
By Shelby
#1872081
Injector Valves!
I bought my Type R about a month and a half ago and within a week the engine management light appeared.
Took it to the dealer and they had to replace an injector valve.
Then a week later the same happened with the engine management light and yet again another injector valve had to be replaced.
Tis fine now though!
Any ideas why this happened? Was it ragged before i got it? :-|
By Gordyctr
#1880812
Watch out for front engine mount, common problem if not checked. Back one can go
aswell then it could snap your studs on your manifold as i found out from tgmsports-racing :shock: lucky for me that had not happen,had an energy suspension mount fitted to the front as this was cheaper than the oem part & is a lot better :thumbup: engine does not rock so much now :WOOT
By JasGun
#1898798
Hi guys this is my first post.
Just brought a 54 CTR (Now know what this means after reading FAQ's)
Picking it up Friday :-D
Took me ages to persuade the girlfriend to let me get one, hopefully there aren't too many problem as I thought it would be reliable. Still cant wait though!!!
Great site :thumbup:
By evilowl
#1912568
Gordyctr wrote:had an energy suspension mount fitted to the front as this was cheaper than the oem part & is a lot better
Energy Suspension mounts are not proper engine mounts, they are only inserts - which is why a set of ES mounts is £30 and a single OEM mount is £115+. They sit inside the OEM mounts to stiffen them up.
By .:mike:.
#1912849
Ok then, good thread - I'm looking to buy CTR at the moment to replace my MR2 turbo. What are the top few things that you would check when looking at this car - i.e. the things that are going to cost £££ to sort out if you miss? I'm used to JDM cars, and therefore the rattles that go with them :lol: Its the obvious things that I may not know about yet that are a bit more car specific!
By trueviper
#1938268
Woo-Hoo!!! Excess road-noise is common with CTR's!!!!
.....and I was sooo paranoid that it was just mine :WOOT
By Ridgeback
#1954461
wow very nice thread thx to all who posted the info.
I Will be looking to buy one in next couple of months and atleast now i have an idea of what to look for.
Thanks :thumbup:
By Newannaive
#1957486
steve29 wrote:is this the same 4 the old and new type r
yes...all faults and fixes are the same.
By effem
#1963420
Hi all..
I am striving to be the latest addition to this owners club since my Escort broke down... (had to happen one day) !!!
Went to a dealers and he is goin to show me a 25K miles type r... 2004 model...(53 plate) with AC. Its obv the facelift version. And with 1yr warranty, New Mats, and a full tank :-D :-D :-D :-D (I found this one really funny) .. and above all ... a LOT OF HAGGLING, he is ready to do it for 9500.
Could u'all help me out on this one ? With any criticisms... catches to look out for... hidden words... etc. Thanks !!
By Z3D
#1967997
Quck question - is it worth coffin up the extra cash for a facelift model, whats the difference between the 2, i kno the lights are differerent but i read that the facelift model is faster due to a lighter flywheel and has better handling, is this true ?
By mark_n
#1968577
oh this buyers guide is perfect! Its made me definitely want a ctr now! Stuff getting the linea rossa convertable mk4 astra!
GET ME A CTR :D :WOOT
By HeavySoul
#1972082
Would the loud creaking noise be constant on a duff steering rack?
Just picked mine up recently - my steering makes a loud, 'clicking' knock when on full turn from the right hand side (it also gets quite heavy to turn). I am hoping it is just a new top mount rather then a steering rack. It has been diagnosed at service last year that a new rack was needed but I would of thought the noise/problem would of been constant if this was the case?
Don't fancy an expensive start to R ownership :???:
By evilowl
#1972596
This thread is designed to answer some of the frequently asked questions when people are looking at a second hand CTR and also hints and tips, it is not designed as a helpdesk thread - so if you have a problem kindly post it in the correct section as a new topic, or better still do a search and find an existing thread as the chances are someone else has already asked your question or experienced your problem.
By HeavySoul
#1972766
evilowl wrote:This thread is designed to answer some of the frequently asked questions when people are looking at a second hand CTR and also hints and tips, it is not designed as a helpdesk thread - so if you have a problem kindly post it in the correct section as a new topic, or better still do a search and find an existing thread as the chances are someone else has already asked your question or experienced your problem.
Sorry :oops:
By manc
#2031180
This is a very helpful thread, I came on here to ask such questions and now they have all been answered
I shall be taking this with me when I start viewing for my first CTR
Regards
By Darth Civic
#2032800
Ahh this one thread is about the best Relevant(to me) ctr info I’ve read so far. I'm an Audi technician & 2 months ago bought me an 05 plate premier with just under 20k on the clock. I've plenty experience in fault finding with similar faults as have been listed in this thread & my car seems to suffers from a few of them :cool: :cool: Here comes my take on it so far.
Steering pulling & self centring problems.
I feel my car pulls about the road slightly when driving @ slow speeds (30ish), not consistently following the camber of the road surface but it just has a wandering feel about it & when briskly pulling out a junction with a fare bit of steering lock on it doesn’t seem to centre properly. I have no noise from the steering & Tyre wear looks even enough. Both symptoms can be compensated for with steering input & are tolerable for now. I intend to do a full 4 wheel alignment on it myself then if needs be buy camber adjusters & line it up. Apparently Hondas factory alignment tolerances are pretty wild :shock: ,if so all Ctrs should drive/feel better after an accurate full alignment.
Heat shield & intake manifold rattle.
The Silver plastic cover bolted to the intake manifold was rattling so has been removed for the time being. I still have the heatsheild rattle from cold, I've not looked @ that yet but I'm used to Hondas so just see that as being part of there character :lol: :lol:
Window Rattle.
My passenger window rattles its tits in only when it’s down part way, somebody wrote that this can't be fixed, I believe otherwise and will sort it when I get the time.
Dash rattles.
My Drivers air vent on the right side of the steering wheel rattles, this is even more annoying than the window & is on the "sort it when I get the time" list. The dash board seems to have developed a rattle from just left of the Radio area since the induction kit got fitted, this doesn’t bother me to much as it only happens when the intake noise changes on Vtec & frankly when that shits going down who cares about the rest!! :lol: :lol:
Knocking from front suspension.
My car has a knocking noise from the front suspension that happens occasionally @ slow speeds/town driving, mainly passenger side, It sounds just like strut tops or roll bar links/inner bushes. (another one for the list).
Road Noise.
There is alot of road noise/wheel bearing type resonating drone. This is a common complaint for cars with stiff suspension & low profile tyres, although it can be loud @ higher speeds it is normal.
End of the day I don't care too much about these niggles, I luv the car & Would recommend one to anybody.
I may update my list as & when I get round to sorting things. :wink: :wink:
Cheers Ewan
New car incoming
