Tools Required
Alloy wheel lock nut key
19mm wheel brace
12mm socket and ratchet handle
19mm open ended spanner
8mm open ended spanner (not essential)
Trolley jack, axel stands and a piece of 4x2
Copper grease
Brake calliper rewind tool (not essential)
A piece of rope/string/cord
New brake pads
Step 1
Slacken wheel nuts on both wheels
Place piece of 4x2 behind rear wheels
Ensure handbrake is tightly on
Step 2
Locate jack under jacking point behind front bumper
Raise the car
Place axel stands under side jacking point and slowly lower car onto stands
Step 3
Remove road wheel and store safely
Remove brake fluid hose retaining bolt
Remove bottom calliper bolt. If bolt spins use 19mm spanner to hold nut on next to rubber boot
Rotate calliper up and tie to suspension securely making sure not to strain fluid hose
Step 4
Slide old pads out of calliper. An 8mm open ended spanner can be used to help ease the pads out. Take care not to damage the disc
Remove the metal shims for the pads. There are two on one pad and one on the other. Clean these with an old rag
Step 5
Push piston fully into calliper. If you don’t have a rewind tool you can use a G-clamp or with a lot of force push the piston with your hands. Make sure to support the back of the calliper as not to damage it
Step 6
Add an even coat of copper grease to the back of the new pads
Refit the metal shims adding an even coat of copper grease to each shim
Make sure to get no grease on the friction material or brake disc
Fit new pads into calliper
Untie rope and lower calliper over the new pads
Step 7
Replace 12mm bolt into calliper and tighten
Replace 12mm bolt into fluid hose bracket and tighten
Replace road wheel and gently tighten wheel nuts
Step 8
Repeat steps 1 to 7 for other side of car
Step 9
Raise car slightly and remove axel stands
Slowly car to the ground
Torque wheel nuts to correct level
Step 10
Check brake fluid level in reservoir and ensure it’s between min and max.
Replace reservoir cap
Pump brake pedal until pedal feels firm again
Step 11
Clean hands and make cup of tea
Admire your handy work!
Step 12
Roadtest the car to ensure everything is ok. Make sure to follow bedding-in instructions supplied with the pads. Applying full braking force to new pads can damage and warp your discs.
Hope this helps!! Anyone in the Fife area needing their pads changed I'll be happy to do it for them.
Andrew
