voted - no problems at all, mines a 54 plate ctr. i work in the trade on jaguars if the cars pulling to the left then when u drive in the centre of the road out of the camber of the road and it drives sraight then the car is fine but if it still pulls then you have problem and if the car pulls to the right then there is an even bigger problem. when carrying out a geometry check on vehicles we use disks from the manufacturers of the machine, not the dealer as in jag or honda for eg. these disks may be old disks with older tolerences also these tolerences can have alot of allowances either way. maybe when any of u guys take your cars to the dealers make sure you go out with a technician to show him what u are experiencing take some tape out with you so you can mark the steering wheel straight position, (maybe the steering wheel is out and needs sraightening before any adjustments are started) once the dealer has done the geo check/adjust ask for the printout and maybe people could post these on here and compare them!!
Also anyone out there whos car drives ok and for whatever reason has a print out could post theirs to compare
sorry its a long one guys,
deano
