gfunk wrote:Well done Nick, thats really constructive
Thank you
gfunk wrote:We are trying to get to the bottom of this problem, and make sure Honda UK are aware that this is a widespread issue, most people simply can't just get new tyres, mine have only done 4k. Anyway if the tyres were that 'crap' why did Honda choose them above all others
Economics and dry weather performance.
gfunk wrote:The problem is not the tyres... if it was wouldn't this problem affect every single CTR produced.
It appears that to some degree it does
gfunk wrote:Think about it
I did and now I have the perfect CTR
It can not be stated too often but the Standard Bridgestone tyres do not seem to work
My car exhibited more and more of the symptoms you describe as the fronts wore, at 10K I changed them for a full set of Gooyear F1
- the car was transformed
- handled just as well in the dry
- HANDLED in the wet
- the high level of road noise was reduced to a wisper.
The tyres that came off showed perfectly even wear on both the fronts and rears. The fronts were approx 60% worn - the rears less than 5%.
At 18K the fronts are maybe 30% worn and rears 5%
