#3855500
Hi!
Some of you propably know me from the for sale section of this forum, I'm the BBK guy ;-) I have decided to show you my '05 Milano Red EDM CTR EP3 :ninja:
This is my third EP3 and 4th Type-R, I also had a Milano Red FN2 two EP3's ago...
Spec:
ENGINE:
- K20A2
- Energy suspension engine mounts inserts
INTAKE:
- CAI Injen
- Hondata Heatshield
- RBC manifold
- 410cc injectors
EXHAUST:
- DC Sports 4-2-1 manifold
- 2.5" catback + OEM backbox
ELECTRONICS:
- Hondata K-Pro
GEARBOX/DRIVETRAIN:
- Wavetrack LSD
- Final drive 5.1
- 4th & 5th gear from JDM EP3
- 6th gear from Acura TSX (for highways ;) )
- MFactory carbon synchros full kit
- Oil: Torco MTF/RTF + Torco Type-F Friction Modifier
- BuddyClub Racing Spec Shifter
- K-SYSTEM.pro shifter bushes
BRAKES:
- Front K-SYSTEM.pro BBK with 324x30 discs and 4-pot Brembo calipers
- Rear K-SYSTEM.pro BBK with 280x8 discs
- DS2500 pads allround
- RBF 660 brake fluid
- HEL braided lines
- K-SYSTEM.pro Master cylinder stopper
SUSPENSION:
- KYB AGX Shocks
- Eibach Pro-Kit springs
- Energy Suspension master bushing kit
- SuperPro front LCA caster bushes
- Hardrace droplinks
- Rear JDM ARB
- Front strut bar
- Steering rack raiser
- D2 Racing rear camber arms
- Powerflex camber bolts
- K-SYSTEM.pro Steering rack slider
- K-SYSTEM.pro Subframe Rigid Collar set
INTERIOR:
- Spa Design Oil temp./Oil pressure gauge
- Civic FN2 Type-R front seats
- BuddyClub shifter knob
- JDM Coin Holder
WHEELS:
- Braid Fullrace A 17x7 ET35
- K-SYSTEM.pro Forged lug nuts
POWER:
- 254HP/233Nm
Pics:
Thanks,
Peter
By PitGTR
#3855528
Thanks!
Rollerdan wrote:Do the fn2 seats sit higher than the oem seats
No, they're few cm lower.
#3855571
N77 wrote:Looks very clean and nice subtle changes.
Your history is the same as mine with Type R's. What colour were your other 2?
Sent from my HTC One mum using Tapatalk
Thanks!
1) Milano Red 30th Anniversary
2) Satin Silver 30th Anniversary (now my brother has it ;-) )
#3855578
Hi did you use the ep3 rails? I wonder if the fn2 rails are better and return the seat to the same position after its reclined and put back after? I am thinking of a set of replacement front seats but fitment is critical, are they the same and function properly as they ep3's?
What's the difference between the anniversary editions and the fn2?
JC
By PitGTR
#3857560
03NHBtypeR wrote:How do you get on with the KYB shocks?
I'm very happy with them. OEM quality with better damping.
