JDP wrote:Made 212whp Only reallygot the lower portion of map done as had fuel pressure issue most of the day which is now sorted, and the springs in the wastegates were basically made from hot dog turds, so back on dyno on 20th to finish off map and make some real figures!!! Got genuine tial springs in, boost selonoid wired in and 4 bar map sensor now so should be able to dial in more boost and run BBG as wellTial gates should've came with genuine springs, never heard of springs giving bother.
What psi spring have you in the wg's?
