By b3nn
#3274556
last year i sold my first ep3 and had owned it for a couple of years from standard and have regretted it ever since. i had to sell her so that i could buy a van as i am now a self employed carpenter.
my old ctr:
however, i found a bargain that i couldn't resist...
bought as spares or repair with misfire on cylinder 1. which happened in 2007, howards Honda in taunton had the car for 1.1/2 hours and couldn't work out the problem, and has been sat around for 5 years without being started or driven so it was up for sale as a non runner. so it was presumed that the car had a major electric fault. It was only 45mins away from me, a bargain i couldn't resist as Ive been looking for another one for ages!
2001 Milano CTR,
33k
1 OAP owner from new.
full Honda service history.
no mot or tax
2 keys and fobs
original receipt from Honda
and loads of other paperwork
came with a private number plate, a set of red mudflaps, heko wind deflectors, an extra set of oem 17" alloys, an extra oem ecu, 4 extra injectors. but apart from this is, its completely standard which is what i wanted. for some reason the owner took all the type r badges off??
when i went to look at the car with my mechanic (Rob from Auto Evolutions) it had been caked in mud, the inside was moldy and muddy. and obv it didn't start, he tried to explain what he thought the problem was. he attempted to jump start the car from his own vehicle and none of the lights on the dash would come on. however he had voltage from jump leads.
we agreed a price and the next day i came to collect it:
on the way back i called in on howards Honda and got a brand new battery and see what we could make of it. got it back to Auto Evolutions in Iliminster where all of the work will be carried out. put the new battery in... nothing. check the main fuses on fuse box under the bonnet and found that the main fuse (80amp) the connectors weren't touching and connected them together and she fired first time! which i was VERY pleased about.
next was to work out why is it was running on 3 cylinders. we checked to see what the reading was on each injector and cylinder one had more voltage that the rest. even with the car turned off it had voltage running to it. as 1 and 4, 2 and 3 cylinders are batched together we ran a cable from 4 to 1 so the voltage was shared, started the car and there you had it running on all four cylinders. i was a happy man!!
so the problem lied within the length of that cable from injector 1 to the ecu or the ecu. we ran the cable from the injector to the ecu and found that it was the brown cable. it ran to the 24 pin plug and it was number 5. we then ran another cable from the ecu around the outside of the car to injector number 1 and still the same. which meant that the cable wasn't damaged anywhere and that the problem is with the ecu.
the following day i set about cleaning the car from top to bottom and seeing how well the car looked after and wash and wax after 5 years! i used my snow foam lance with karcher jet washer and then gave the car a much needed polish using a autoglym super resin. i then hoovered and cleaned the inside which took some time. the dash was covered in mold and interior wasn't much better.
here are the results:
My plans are to keep the car off the road for a few months and progress with it, finishing off with a turbo or supercharger. :P
#3275879
as the car has been sat around for a long, we thought it would be a good idea to see how bad underneath the car was. the underside was caked in mud and had areas of surface rust, so out came the wire brush and some good old elbow grease. started by cleaning the floor plan first then used black under sealer and then went back to the original colour which finished it off nice.
as for the arches they are covered in ground in dirt so out came the wire brush again. all four have cleaned and now ready for the same treatment under sealer and sprayed back to milano red! and in the next couple of weeks i will swapping the old springs and shocks for a set of coilovers and all new camber adjusters. and as for the brakes, on the front il probably go for stoptech big brake conversion and have all new brakes on the back.
Before Pictures of the Arches:
as for the front wishbones and rear subframe, i will be removing them and have them sandblasted and probably spray them red, as at the moment they arent looking in the greatest shape.
i then decided to see what mystery was hiding behind back and front bumpers as for the back, the bumper bar is also going to be sandblasted and sprayed as it has gone rusty which they usually do. however the front bumper bar was fine so it stayed on. i gave both areas a clean and got rid of all the leaves and dirt.
and as i had the bumper off, it would rude of me not to fit my new h4 hids 6000k that i got for £25!
#3276911
Cheers for the comments guys, and yes I have got my work cut out... But il get there in the end!
Quick question to anyone that has any...
Does anybody have a set of old
oem front brake pads that are low and wouldn't mind giving to me if I paid for postage, as when I bought the car it didn't come with any because they had seized on.
It would just make life easier with brakes in and out the of workshop lol
#3279031
i had a few hours spare the past couple of evenings to under seal all 4 arches in black. then go over with milano red to finish it off. i attempted to go round all the plastic inner arches as i didnt have a newspaper to cover them with. i think it looks alot better than all that ground in mud.
Pics:
and a quick picture of the arches with the wheels on, minus the rear bumper:
  • 15
