So I it sll started in jan 2009 when I got my ep3 ctr after missin vtec for 4months when I sold my B20 civic jordan for a M3.
cheeky vid of m3
I got the type R pretty much standard apart from apex lowerin springs and tinted windows.
Before I got the car home I was on the fone lookin for an exhaust system for it.
After getting an induction kit and 5zigen catbac system on the car I was impressed when I pulled 14.6 down the 1/4 on road tyre and no lsd.
So after a couple months I got bored and decided to go down the turbo route. Fitted the kit myself and learned a lot from it.
made the stencil for the intercooler and painted it
fitted block guard
before
after
when i finally got car runnin it was pretty fast but thought it would have been quicker but the it could just have been that the turbo had full boost under 4k so their was no big kick from it. had a couple of races that i have on vid.
Tried to go the cheap route and map car with a uni-chip as they were meant to be able to do the job i melted piston no.1. so engine came out and got some work done
so i ordered up somesome parts that i needed
while car was off the road with engine out the car got broken into with things like boost pipes, dump valve, vtec controller, guages, intercooler etc gettin stollen it put me off te build and thought bout breakin and sellin up. then i knew i wanted to keep goin so thats what i done.
so after gettin block decked bored out .5mm, balanced rotating assembly i got a start to buildin engine parts list is:
full ACL race bearings
cp pistons
eagle rods
arp head studs
cometic head gasket
facelift flywheel
clutch masters fx400 clutch
polished head
machines throttle body
also treated myself to new guages and intercooler since some w4nker stole my old ones and got an external oilcooler as well
so after loads of problems that i wont even go into.......i went to tdi north
best thing i ever done. car wouldnt make any power and they told me everythin to check
turns out my turbo mani was to small and was restrictin the flow. they advised to ditch the 5zigen and get a 3" exhaust and a better feed into the turbo. so all the way home made a 3" exhaust, 3 1/2" intake into turbo bought a spoon engine torque damper from vic (V_type_R)
so i tidied up the engine bay a bit fitted new turbo and went back down to tdi for 2nd attempt for mappin.
this time it went well. 9psi made 317.9bhp 229.2lbft then their was high boost
i was pretty happy with car but paul said the turbo was crap lol and should be makin more power on high boost.
so i took it to knockhill and was runnin low boost as turbo manifold was crackin again. very happy how i did on the straight but my standard brakes and suspension didnt like it much. im sure most of you's will have seen my bump lol but if not here it is
http://www.youtube.com/watch?v=fJzovUg3GeY
so after that the duck tape came out
was bac out on track in no time and then the turbo went pop lol. here is the vid that bornlucky1 got while in an m3
http://www.youtube.com/watch?v=ISE7SQJjNYQ
so got bac to garage stripped down car turbo has sheered the shaft so i have bought this bad boy
my old turbo housin against new turbo
which means gettin new manifold as it doesnt fit behind the engine. so in middle of makin new manifold for the car the now. o and accident damage has been sorted :thumbup:
and car has been painted........and its changed colour
ok so my manifold is spot welded together need to get to my work to give it a proper weld with a decent welder still need to fit pipe for external wastegate as well but as much as i could do at my garage hers's some pics
let me know what you's think.
to be contined...
Russ Paton tuned civic turbo
