#3578458
Spent a day up North yesterday visiting Stevie @ Grinspeed, looking at my gear box.
I bought a set of Mfactory syncros from Stevie to sort out my box that was discovered to be in need of syncros when I had my diff fitted a while ago, had to put the box back together without new syncros (funds did not allow) and was surprisingly fine for many miles and trackdays since, but I had a low rev crunch or two a few weeks ago so finally had to sort it out
Grinspeed spotless garage (filthy by Stevie's standards apparently)
mmmmmm, carbon syncros
stripping the box
where did this bit go again?
nice bit of swarf
all done, now time for a test drive
Cheers Stevie, great work, nice cups of tea and even a cream cake (now everyone will expect one) :salut:
#3601817
Had that Clockwise flywheel fitted yesterday by Stevie @ Grinspeed
old clutch
new flywheel in place
Changed near side CV joint (thanks tuf) and Stevie sealed up a small nick I had on the other sides CV, he also noticed a bit of play in the off side wheel caused by a failed track rod end so a quick call to his supplier and an oem came in a couple of hours.
I then asked for him to check my geo with the Rebel track day on thursday in mind, found I was running 8mm toe in!! he straightened that up a bit and it's made it much less of a handful but not so "chuckable" if early tests are right
and although we didn't have the time for a proper corner weighing we did pop it on the scales for a quick check:-
:bigthumb:
1158kg, not bad, that's with a quarter of a tank of petrol and all the oils - those seats must have been heavy :-D
  • 9
  • 15
