- Tue Sep 10, 2013 9:10 pm
#3684635
Its a bit of a pain to be honest, the whole side plastic has to come out, also part of the seat I believe. Start at the back and take out the centre boot plastic, then unto the parcel tray holder plastic, then pop off the speaker cover and remove the speaker, remove the plastic panel that covers the strut top next to the seat, there should be two push clips holding the plastic down one in the boot and one under the seat bench. To remove bench theres one bolt down the back of the seat bench between that and the upright section, it then just pops out, hopefully that should be all of the seat that needs removing.
Then start pulling the panel away from the side of the car, the clips make a lot of noise when they come loose, remove the seat belt rail part thats next to the seat, the plastic hooks around the side of the door so it needs to be pushed forward a bit to release it.
Should be everything, I put all my interior back in the other day so hopefully I've remembered correctly [smilie=karls_thumb.gif] Also the seat belt has an electrical connector for the SRS system, disconnect the battery and allow a few mins before undoing this!!
