We have achieved the required number so now it will be a discount of £15% for members order.
The Deadlinefor this group buy is now set at the end of September. (Payment can be made later)
RRP for the EP3/DC5 Zeta-R Coilovers is £679. Therefore, the group buy price will be £577.15 + £15 P&P (UK Mainland)
This group buy will include the following model:
*EP3 Civic
*DC5 Integra
*FN2 Civic
*FD2 Civic (Specially designed to provide more comfort than the extremely harsh standard JDM suspension)
---------------------------How to order? Price?---------------------------
Simply place your order here: http://www.cyberspeeds.eu/index.php?mai ... Path=70_85
On check out, input the voucher code CTR15 and the 15% discount will be added to your order
All coilovers are in stock and ready for delivery as soon as we have enough people interested. :thumbup:
Note: I can offer CyberSpeeds Rear Camber Arm / Rear Lower Control Arms, and Eibach/SPC Rear Camber Kit.
If you are interested in adding some optional accessories to your order, just let me know and I will sort you out.
If you have any problem, please feel free to PM me.
MeisterR Zeta-R Coilovers for Honda Civic (EP3 / DC5)
The Zeta-R Coilovers had many adjustments made in order to make the coilovers better for everyday fast road uses. The basic remains the same as before using high quality adjustable monotube dampers, linear rate springs, and a modern dual perch coilovers design. Zeta-R have revised damping specifically made for the UK roads, longer damper stroke travel for the bumps and dips, and 32 stage damping adjustment for fine tuning your desired ride.
Spring Rate:
EP3 - Front: 8.0 kg/mm (448lb/in) Rear: 10.0 kg/mm (560lb/in)
DC5 - Front: 10.0 kg/mm (560lb/in) Rear: 10.0 kg/mm (560lb/in)
Aluminium Top Mount with PillowBall Bearing and Camber Adjustments.
Anodised Red Aluminium Top Mount with Integrated PillowBall Bearing and Camber Adjustments replace your worn out steel top mount.
The Camber Adjustments allows precise setting of your front camber geometry (No need for Camber Bolts) and will reduce tyre wear from excessive negative cambers from lowering.
MonoTube Dampers with Black Chromium Plated Body, Cold Coiling SAE9254 Chrome Silicon Steel Springs
MonoTube Dampers ensure high performance damping and ability to dissipate heat under hard usage.
The Black Chromium Plating have endure salt spray test and is by far the best anti-corrosion plating available.
There are 32 stage damping adjustment (Compression and Rebound Combined). Lengthen Rubber Boot ensure the damper piston will be protected from harsh environment.
The Cold Coiled Linear Rate Springs use high grade SAE9254 Steel to ensure strength and provide linear and predictable weight transfer characteristic.
Anodised Aluminium Spring Perch and Locking Collar
Lightweight Aluminium Collars are use to lock your springs and brackets in place.
The "Polyamide" springs isolator are use to reduce noise and spring binding issue associated with rubber isolator.
Steel Lower Bracket with Straight Arms Design.
Steel Lower Brackets ensure strength are maintain during hard usages.
The Straight Arm Design reposition the track rod end to a lower position than standard.
This design allows the angle of the track rod to stay near factory specification after lowering and therefore relief the stress that are place on the track rod end.
This prolong the life of the the rod end and eliminate the need of an inverted track rod end kit.
By keeping the track rod angle close to the factory specification, it also reduce "bump steer" issue that are face by many EP3 / DC5 owners using lowered suspension with the standard "V-Shape" arm.
Here is a picture from our members jreedy
Just thought I add that the CyberSpeeds Roll Center Adjuster are now in stock, so no need to search for them anymore.
Use Voucher Code CTROC when ordering on www.MeisterR.co.uk
