Tools required
flat screw driver
philips screw driver
10mm sockect & ratchet
First unscrew & unclip the wheel arch from the front bumper 2 clips 1 screw on each
There is a clip holding the inner ach in place remove this to allow access the arch clips. Now loosen the clips holding the wheel arch trim as before on the rear. Unscrew the philips holding the bumper to the wing. remove the 2 bolts from underneath the front of the bumper along with the clips and save.
Remove the number plate and the screw behind it. The bumper is now free, slowly start to gently pul the bumper from 1 side and it will un clip. You will need to disconnect the fogs if you have them. Put the bumper onto a sheet . Remove the clips
The new splitter will now clip in to place from the centre out both ways plut the connectors screws back in place.now repeat the process in reveres to complete.
This took me about 1hr easy , you have just saved yourself £££££££££££££££££££££
Original Links
http://i84.photobucket.com/albums/k13/illeagalhunter/Picture049.jpg
http://i84.photobucket.com/albums/k13/illeagalhunter/Picture037.jpg
http://i84.photobucket.com/albums/k13/illeagalhunter/Picture051.jpg
http://i84.photobucket.com/albums/k13/illeagalhunter/Picture054.jpg
http://i84.photobucket.com/albums/k13/illeagalhunter/DSCN0076.jpg
http://i84.photobucket.com/albums/k13/illeagalhunter/Picture055.jpg
