By canman
#2268634
So the whole intention from the start of my EP3's build was to have it supercharged...... engine was built with custom made lower compression pistons to help control detonation once the extra boost was there, but for one reason or another we never got around to actually fitting the supercharger......
Well that's about to change and although I know others have a supercharger already I figured there's a fair few that haven't and might be interested in what's required and just how easy it is to achieve. I'm going to try and take pictures as we go and of course will post before and after dyno plots so we've got some comparisons.
Had a good look at the Gruppe M intake kit and I really didn't like it even though it's the psuedo standard for EP3's so I thought I'd try something else which I think will fill out the engine bay just as well, be a bit different and work just as effectively from a performance perspective and overall ended up cheaper too.
Haven't finished that side of things yet, but shouldn't be too far away and I'll post some pics and info. For now here's some strip down and build up pics of things as we progressed. STM is Speedtech Motorsport http://www.speedtechnz.com . They're really good friends and I've been working with them on my cars since 2001 ish.
The owner Andre Simons is also the owner of "DOCILE" the 1400HP + EVO drag car which I believe is one of the fastest in the world. He's also the tuner of Reece MacGregors GTR which is the fastest GTR in the world at the moment and is some 1700HP ........ so he's capable enough.
Supercharger kit was supplied by someone you'll all know in Guy from CPL......... what a totally nice bloke.....
Obviously the first step was to remove parts needed to accommodate the new supercharger kit. Off came the intake pipe, fuel rail, injectors, throttle body, intake manifold, drive belt & tensioner.
What came in the box from CPL.
The next step was to remove material from the back of the auto tensioner mount to clear the S/C plenum. The intake ports were taped up & the motor covered to prevent any of the aluminum swarf getting in any where it shouldn't.
The instructions were just as well thought out as the kit itself.
Once I had that right it was time to bolt the S/C plenum & supercharger to the motor. Fraser already had a Gizzmo Intake gasket fitted & as this was still in good condition it was decided to re-use it. It was cleaned down & sealant applied.
Torquing the plenum on.
The throttle body adapter was next to go on. Loctite was applied to the cap screws & fitted.
The factory throttle body was cleaned & bolted straight up to the adapter. The water lines & throttle cable both went on without modification.
The new manual belt tensioner was bolted in place of the auto tensioner. Anti-sieze was applied to the supercharger pulley shaft to prevent the pulley siezing on over time.
The pulley was fitted along with the nut, torqued up, belt fitted & tensioned.
The Map sensor is mounted on the throttle. As the supercharger is fitted after the throttle body the Map sensor will not see any boost. A special adapter was supplied which houses the factory Map sensor in the factory location. It blanks off the port into the throttle body itself & has a hose nipple which is plumbed up to the plenum solving the problem.
The new RC Engineering injector O-rings were lubed & slid into the fuel rail.
The new injectors call for new injector plugs. As with everything else, it was supplied in the kit.
The kit installed (minus an intake pipe)
An upgraded clutch was installed during the Civics stay to handle the extra power output. So here is the freshly machined flywheel.
Here is the Exedy 3 puk clutch & heavy duty cover.
With the gearbox back in & wheels on I had some fuelling pulled to allow me to run the car & bleed the cooling system. Once this was all done & everything checked over the car was given to Andre to get bolted onto the dyno.
Andre was kind enough to do a little write up of the process after physical install and what's required to get it ready for dyno tuning.
"Fraser’s civic was previously equipped with a Hondata K PRO ecu which we had mapped when the engine was still naturally aspirated. We had ended up with 155 kw (208 HP) atw in this form which was up from the 143 kw (192HP) atw base run when the car came into the country. Considering we built the motor with lower compression than stock to suit the supercharger, this is a pretty typical result and shows just how good these motors are. It wasn’t that long ago that achieving 74kw (100HP) per litre or more from a naturally aspirated motor was only for all out race engines!
Getting the engine up and running on the JRSC kit was very straight forward. First the injector scaling needs to be changed to suit the 650cc RC engineering injectors. Critical to this is entering the correct injector latency values which RC don’t actually include in their specs for some reason? After these adjustments the engine started up just like a stocker.
After initial checks for leaks etc and bleeding up the cooling system, the car was bolted up to our Dynapack chassis dyno. For tuning it is critical to set the ecu in openloop mode, otherwise in closed loop the ecu will be correcting for any difference between the target AFR and the actual. While this might not seem important, we try and make the ecu’s job easy by keeping the trims small. This means the tune will be more accurate and the driveability will be improved.
After warming up the engine and making some basic changes to get the fuelling where I wanted it, we could perform some base runs. The K PRO can be a bit of a nightmare to tune if you don’t have a strategy to approach it with. Not only are there high cam and low cam maps for both fuel and ignition, we also have 6 maps available for the intake cam position. To make matters worse the intake cam position can be set to any position at any combination of rpm and load. On the plus side, with a competent tuner on an accurate dyno it is possible to optimise torque at every point in the map. On the other hand it is equally possible to tune the engine into a dog that performs poorly with terrible driveability and fuel consumption.
We start by choosing a cam position and fixing it all the way through the rev range. We then perform some runs and optimise just that cam angle. Once this cam angle is optimised we then switch the position to the next cam angle and repeat the whole process. Once all the cam angles have been optimised we should end up with 6 dyno plots which intersect. By choosing the cam angle that corresponds to the peak torque at each point through the rev range we can build up a map of target cam angle. This should provide a perfect map with the maximum amount of torque shown everywhere on the dyno plot.
Optimising the VTEC point is pretty easy in comparison. We normally do a run with the change point set very low, and another with it set very high. The point where the resulting plots intersect is the ideal change over point. Mapping the cam angle at part throttle is a little trickier, but the principle is the same.
The first thing that was obvious was that the boosted motor now wanted to operate over a much narrower range of cam angle. While in NA form the cam angle at full load wanted to move between 20 degrees and 50 degrees, with 5 psi boost from the supercharger the cam angle only wanted to be moved between 40 and 50 degrees.
The second issue that became apparent was that we weren’t seeing the sort of boost we were expecting. While the kit should have given us 8 psi of boost, we only saw a peak of just over 5 psi. This resulted in our somewhat uninspiring 198 kw (265 HP) atw result when we were expecting 220 kw (295 HP) atw. Some digging from Fraser showed the crank pulley to be responsible for the low boost. We are in the midst of getting a larger pulley onto the car with the aim of 8-9 psi. Then it will be back on the dyno for a touch-up to suit.
Cheers,
Andre"
By evilowl
#2268644
Love the time lapse, still think your car is one of the best examples I've seen on here mate especially with all the custom fabrication. Good work :salut:
For the benefit of all the newbs
By Drucifer
#2268813
If I had my time again, I'd make a DC5 kit fit (a few adjustments here and there), then fit an aftercooler :cooldude:
By canman
#2268848
I'm glad you guys enjoyed it....... was the only reason to post this stuff up here.......... I love reading through semi technical/build up threads too so thought I'd share in case it was of interest to other users, glad it was :D
I'll keep posting more info as it comes up.
Thanks also for the nice comments regarding the car........ it's been a long road to be honest and am just in the throws of starting my next project ....... Honda NSX racecar..... I know it's not a CTR, but maybe you'll be interested in the build up ?
By canman
#2268964
Not sure what Funkypowers NSX is like, but this will be strictly for club level racing nothing more, I want to compete in our Targa New Zealand eventually which is 2000km's or so across the country over a week or so on closed public roads....... awesome just to finish so I'm not out to win it.
I'm starting with a 1991 NA1 car with 60,000km's on the clock. STM are helping to prepare the car and I'm also getting help from Driving Ambition in the US as I have had dealings with them through some other business connections and they're NSX specialists so it's a great way to save development money since they already have made the mistakes before to save me doing the same !! :)
I have already purchased the widebody kit which should be here in a few weeks from Australia....... this is their demo car,
It's part Sorcery kit from Japan with a lot of their own custom work and their own design front bumper and guards. I've also got the airjack system from a company who's developing one...... it's all built on board so you don't need an external supply to life the car so it's perfect for trackdays and club racing.
This is the rear wing I've decided on...... I think it'll look the dogs danglies with the wide body kit
But I digress.......... that's a little while away from posting up a build thread, but I promise I will post it here if you're interested as you mention.
Damian1, from what I've seen of the dyno plots so far (haven't had chance to drive the car :( ) it's going to be bloody awesome........... I think you'll love it, but for the GB spec cars I'd say getting an LSD is essential. I'd never consider it without after driving a UK spec car and my JDM spec car in NA form is still quicker I reckon in real world situations due to out and out grip.
By canman
#2268970
Drucifier, I chatted with Guy at CPL and a couple of other trusted tuners at great length about the DC5 kit and aftercooling and all were of the same opinion. The cost and complications associated with it simply didn't net the gains that you'd expect.
Although it did lower intake temps, the Supercharger itself was getting well outside it's efficiency when you ran it hard enough to require the aftercooler so it kinda made it redundant. When running them at 8lb for instance the temps are more than managable and so there's really not much benefit to lowering the intake temperature relative to the cost that it would bring. Yes if you could do it relatively cheaply and easily then it would be OK but to be honest if you want more than 300HP at the wheels and nearly double the factory torque in places, then surely turbo charging is a far cheaper solution for much greater power.....
I hope that makes sense .......... general concensous is that if you want more than the standard kit is offering (ie 300HP as mentioned) then go turbo charged.
By Drucifer
#2269010
My thinking is that it is something different and no one in the UK has done it with an EP3, and a personal curiosity of seeing how far the technology can be pushed. I've seen the results from RSX owners over the pond and they're running a noticeable gains for less than $300 with 10/11psi pulleys without meth injection.
More info here: http://www.k20a.org/forum/showthread.php?t=57212
When my charger comes off for a service I'll be polishing all the insides as much as possible and see what the blower is capable of.
Some info on porting and polishing here: http://www.3800supercharger.net/p&p.html
There are easier ways in getting more power, like a turbo, but there is an additional element of delight when you have something no-one else has and you've done it because it's challenging, not because it's easy.
By canman
#2269068
Yeah I totally know where you're coming from............ I am the same with a lot of things, I suppose for me I had bigger fish to fry as it were as I wanted to put all my spare time and cash into other projects so I was really just looking to fill the big low down torque hole that the CTR has and I think that makes it just perfect, I've got my GTR if I want to chase perfection :cool: I think there's a couple of other GTR and CTR owners on here.
Although I did do a lot of reading about what you're considering, I'll have a read of what you've posted as I always find that stuff interesting and I suppose as with any good car nut you're always happy at first and then start craving for me eh....... so thanks for the info.
By canman
#2269528
Just the 2 at the moment and the NSX is the third.
CTR was meant to be left stock and was going to be my daily driver as I had driven my GTR as a daily driver for 5 years and although it's an awesome car I thought it made more sense to have something smaller and cheaper to run daily. As I'm a bloke it didn't manage to stay stock for very long as I got the bug and ended up doing the bodywork and the chrome finish (for those who mentioned it, it's Mirrachrome from Alsacorp ( http://www.alsacorp.com/products/mirrac ... odinfo.htm )
Since the whole reason I got a CTR was because I'd driven the Abbey Motorsport CTR with a supercharger I had to do that too.......... Now I'm sick of having to try and make a road car work well on the track and so I've decided to do something really different and get the NSX to build a dedicated track car.... They're only about 14-15,000 quid to get one from Japan so they're not rediculously expensive to start off with and they're light and have plenty of potential, but it's going to be expensive in the end once I've got the supercharger kit and 3.5 litre motor, brakes, Moton suspension etc etc, but I'm not forced to do that stuff to start using it so I'll just work on it slowly as I've done with the other cars.
